SOLVED:
Ended up just using a pressure gunge I use for checking water mains pressure when I'm fixing retic systems. Has 25psi at idle (maunal says should be 43psi) and would drop to 18 when reving it up with no load. So bad pump.
I've replaced it and now it runs like a champ.
