what ever you do dom. NEVER PUT A USED LIFTER ON A DIFFERENT CAM LOBE. unless the new lifter was run in to the particular lobe never ever swap them around or you will destroy the cam lobe, flat tappet lifters will surface harden as they run in agains a particular cam lobe swapping the lobe a lifter runs on is a sure fire way to wape a lobe off the cam.
http://www.cranecams.com.au/pdfs/Rea...%20Failure.pdf
and you must go through a break in procedure when fitting new lifters even on a used cam
http://www.cranecams.com.au/pdfs/CAM...0PROCEDURE.pdf
the only lifters that can be swapped around etc are roller lifters
