Yeah this part im not sure. jff45 knows about this part, as he did it to his GU.
If you already have a GU 4 speed auto you just need to redrill the bellhousing to match the TD42 starter motor. The choice of flexplate will depend on whether you have a N/A TD crank or TD42T/Ti with larger journal. The flexplate will also have to match your choice of torque converter.
I initially used my TB45E TCU but have now swapped to a ZD30 TCU which changes much earlier. You need to retain the ECU for either the TB or ZD TCUs to work.
I also initially used a ZD30 TPS on the foot pedal but now use a TD42Ti (3 wire) TPS on the injection pump because I had issues with my cruise control not activating the TPS on the pedal.
Every TCU for the 4 speed auto requires a TPS signal. I added a cable to a ZD30 foot pedal/TPS to replace my TB45E foot pedal. Secondhand ZD30 stuff was $50 and TD42 TPS for auto was $250 at the time.
Here's a pic of the bracket I fitted to the ZD30 pedal to pull the cable.
Attachment 73301
Thanks jff45 that looks awesome.
So when I get my loom redone I need to mention that I’m keeping the tps sensor. Would I be better off getting a td42 auto pedal? Would it work
Sorry for all the questions
Will the stock 4 speed auto from the zd30 be able to handle the td42
I wouldn't expect a TD42 auto pedal to be any different from a manual pedal.
If you modify your ZD pedal to take a throttle cable, I don't see any reason to get a loom redone. You can adapt your current wiring easily to fit to the TD requirements.. just depends how handy you are.
If using the ZD T4 torque converter, best to get it stalled a bit lower. I'm using a stock J6 TB45E TC. Your auto will need a good valve body or, at least, a Transgo shift kit.
Personally, at 300k kms, I'd rebuild it and add the extra clutches.
There are now a few TD42 autos getting around and there's quite a bit of info about them out there..
Not after re-reading your original post.. if you're talking BW turbo, 12mm pump, blah, blah then it's going to be up there power wise so you'd better discuss it with a good trans shop.
Seriously, with all you're dreaming about doing you're going to need deep pockets and a shed load of good advice. I'm not sure I'd be using a 300k kms 2000 ZD30 as a base to start from. Just my opinion and it's your money after all..
Can you recommend any good shops?
Yeah I’ve had a few people tell me that it’s more because it’s a special car to me and my family served us very well then the owner ship came to me.
Well I’m all ears for good advice so bring on all your opinions and advice mate I’m all ears
