the frenchy
yes I know what you mean but before doing that I should be verify if the oil filter has the good size for the plate... And now that I know the filter is an industrial size model, I fear the bore of the filter was superior than the plate and was useless... :/
I think I could do a system fitted in the pressure sensor plug of the engine with derivation and multi plug for the pressure sensor and temperature sensor... I should be work on that option : more fiability against the leak and much more simple than to doing some parts in a machining aluminium with no warranty to success ^^'
