3 words
Made in China
and a few more for good measure bulk orders placed with the Chinese manufacturer
I got mine for $375, but no freebies. As for the install, pretty straight forward mate.
Just be prepared for a long wait after you order.
I have a set in my GU and a mate has a set in his GQ. They are really good value for money but:
* They weigh 85kgs which is seriously heavy
* The drawers only slide out about 80% of the way, they use roller bearings instead of drawer style runners
* The fridge slide only slides out about 80% of the way, and it can't be swapped to the right side
* Buy yourself a cordless screwdriver, there are literally hundreds of screws to do up
* They can be tricky fitting if you have a rear cargo barrier, consider getting some adhesive rubber strip to go between the drawers and the cargo barrier to prevent squeaking noises
* Be careful when fitting, they have really sharp edges
* The rear seat belts can be left in, the drawers go in around them. On the other hand, once fitted the seat belts are not much use
* I trimmed the metal around the jack cover so I can still access it
* FOLLOW THE INSTRUCTIONS CAREFULLY - I didn't and had to remove the tops to fit the drawer stoppers
* Use loktite on the screws, they seem to come loose easily
In spite of all the above, they are really good value for money
Thanks everyone. I will go and have a closer look at the display stock.
I have my rear electrics wired into where the wings go so will see if I can modify to enable me to still access this.
