Absolutely must be water tight including some silicone in the drain on the primary filter housing (td42) dunno if others are the same
Yes, and going from stories ive read, unfortunatly getting it fitted by a retailer that sells snorkels, does not always "guarantee" your snorkel is fitted correctly .
If you do choose to fit one yourself, i suggest you don't use any old silicone, but use a Automotive Adhesive-sealant product from the "Sikaflex" range, its a Polyurethane and much stronger, plus it wont encourage rust, is sensor safe, and comes in Black (other colours are available)
Hi,
thanksd, very helpful information here. Any suggestions where to get a snorkel, preferably Safari for cheap? I anyone in the Forum selling snorkels or knows a place to save a $ or two?
thank you guys,
Chris:blowup:
I found these guys had pretty decent pricing on Safari brand snorkels
http://www.olbis.com.au/ap_template/...ri_snorkel.asp
Just to give you a rough idea...
If you plan to do it yourself, you may need a large hole saw, and air hacksaw or tin snips etc , plus Sikaflex , some paint (to cover bare metal after cutting) and a drill/drill bits.
Id never fitted a snorkel before and a Safari on my GU took me 5 hrs (not sure about GQ fitment) , i did spend almost a hour modifying a few things i didn't like with some of the pipework tho.
In general,i found prices for snorkel installation (GU, again not sure if that makes a big difference ?) seemed to start at around $250
Oh and if you are checking water crossings, check that it's not a crocodile zone, as a snorkel won't help there. The rest is as everyone said, seal it up and fit a precleaner or filter if it's real dusty.
Why a safari? I got an ironman supplied and fitted for $580. Still not the cheapest item you'll put on your rig, but just like my panel chop today - if you value the vehicle and are not 100% confident in doing it, then get someone who knows how (and who has to warrant it for both product AND installation, which includes rust treatment - if you install the safari or any other brand yourself, kiss the warranty goodbye!).
Just my opinion - others on here have done theirs with great success.
Seems like cheap once off insurance to me
My Safari Snorkel for my GQ (GU was the same price) was $419 and me and a mate fitted it on Sunday. Safari for me represents proper R&D from a trusted brand and also is australian owned and made. For fitting yourself, you will need the:
- holesaw bit ~$40
- masking tape ~$2
- drill ($50-$700 depending on quality - I would recomend buying an impact drive drill so you can take wheel nuts and other random bolts off also with it EG: http://www.ebay.com.au/itm/280600450857?hlp=false)
- drill bits ~$20
- step drill bit up to ~20mm (16mm for the GQ) ~$20 for a set
- some rust proofing coating ~$10
- a caulking gun ~$10
- some non corrosive silicone ~$7
extra $115 + drill + self satisfaction
If you dont have these things it can be a costly job to go get them. But purchasing them will be an investement for future mods and also DIY's around the house.
I wasn't completely comfortable doing this to my troll so I asked a mate who was comfortable to give me a hand, no worry's.
The mob I bought my snorkel off was sunshine state 4x4 at Archerfield
