Valve timing is good. No dramas with the timing belt.
Dizzy is properly placed on TDC spot with number 1 cylinder.
Ignition timing was way off yesterday when I checked the timing. It was about 20 degrees advance.
That came out as a surprise, 'cos I thought it was lot less than that.
I've got it sorted out. A silly mistake of getting the correct side of the rotor tip mixed up.
Hi Guys, I been using this type of spark plugs from the UK called Brisk High Performance Spark Plugs on my GU. August 2014 installed and car running great on both fuels , below is a ebay link . hope this helps cheers
alex
http://www.ebay.co.uk/itm/6x-Brisk-L...item568433581b
