I have an Icom jr had it for years and also have a GME 6300 I think a 5 watt unit.
Hopped onto Ebay and brought some headsets for both, very handy,,,,lol
Love that web site @DaveGQ I have up dated both of mine with a larger antenna etc etc
The only problem I have found with hand helds is that when you really, really need them - the battery is flat. Make sure the one you get can either be operated from an external 12 volt source (some cannot be operated when charging) or you can get a battery pack/holder for it that takes normal AAs or AAAs.
It's also a good idea to remove the battery when you are not using them as most have some sort of memory that uses some battery power even when they are switched off.
I have an emergency hand held in the door pocket that works on AAs and I keep the radio in a bag with a set of lithium AAs (as they have around a 15 year shelf life).
You're right TPC, sorry. Aussie brand more like it.
Great radios tho, it's pretty much on par with the Motorola ones we use at work (heavy industry), in terms of build quality.
