no idea how i pulled it off, but on a trip out dargo way it did 13l per 100km on the fwy between werribee and sale
If you follow the part numbers of the auto tranny between petrol & diesel one from the repair manual, that should be able to tell you.
I thought turning the dizzy is a no gone zone for EFIs as the advancing/retarding is done by the ECU once the valve timing is set manually.
nah nothing clever, just 2" lift 33"s and loaded to the hilt heading bush. i couldnt believe it so i had 3 people check my calculations
yep im sure, only thing that i can say it it was not long after doing the head so everything was fresh, plugs leads, injectors cleaned, new 02 sensor, new temp sensor/sender etc
Hey Billyj, I have found the ECU stuff on the net It looks like I just need to purchase the plug and cable , already down loaded the software for it.
Once the cable turns up I supose its going to be a real learning curve for me.
all the software and cable will allow it to read the sensors in real time, so you will see differnt numbers going up and down etc, it showed i had a blown o2 sensor as its voltage should fluctuate and it was sitting on a steady .3v and never moving fitted a newie and moving between 0-1v like it should
You must have done something right probably following a bit of gut feeling.
That economy is damn good.
I would like to get good fuel economy from my troll(RB30 LPG), without shortening the lifespan of the motor, of course.
I haven't seen any difference between EFI converted RB30 & properly tuned carby/mixer RB30.
Of course, I'm going by what I've heard so far.
