:confused:Sorry for being ignorant but what is "Axle Articulation"?
Is it good or bad to be reduced?
Axle articulation also called flex in simple terminology is the travel of the axle from maximum stretch to minimum compression if that makes sense, how far each wheel can travel up and down. This is the reason a lot of us do suspension upgrades with a lift it gives more travel over standard, so with an air bag i would assume you dont get as much upward travel because the bag is there and stops maximum compression
So reducing articulation for someone who prefers to do more difficuilt 4wd it is definately worse as you will lift wheels off the ground more regularly therefor loosing traction, then to counteract that loss of traction we start spending money on diff locks and other traction aids, more aggressive tyres. in saying that loss or reduction of articulation will effect all terrains mild to wild. Solid axle front ends as in patrols some cruisers etc have more downward travel than independant (IFS) front suspension vehicles as in prado pajero later model hi;lux's etc.
