Quote:
Cuppa
With ctek you have to be careful if buying one intended for a smaller battery bank beause there is a chance it will overcharge the battery if left unattended. I had a ctek 7 amp charger on 300Ah of batteries & this was a problem. It has to do with the how ctek chargers 'check' the battery every 10 days when in float mode. My ctek had a 'Supply Mode'. I got around the problem by montoring the battery until it was full, (ie. dropped into float mode) & then switched the charger to 'Supply mode' which I could leave indefinitely. If buying ctek I'd suggest it is best to stick with the models suited to your battery capacity.
If it's a Ctek smart charger, it should cut the amps as the battery reaches it's full state of charge.
As much as to almost zero if the battery is "100%" full. If a smart charger overcharges a battery, that defeats the purpose of a smart charger, I reckon.
Quote:
I had a 0.8A smart charger (not a ctek)supposedly intended for 'permanent' connection plugged into a wet motorcycle battery years ago. No mention in the instructions to regularly check & top up the battery fluid. It killed a new battery in less than 12 months, being plugged in whenever the bike as in the garage.
Ideally it shouldn't, if it's a properly working smart charger.
But, I don't leave them plugged anyway. I reckon it's a waste of electricity(not money. :) )
I charge the battery once a month with a mains electricity smart charger and a pulse charger.
Appears to be doing a really good job by keeping the battery going lot longer than it normally does.
Quote:
Whichever smart charger you buy, you will still need to check the battery fluid regularly & top up as needed (if a wet battery) or risk it dropping the fluid level below the plates, or even boiling it dry. This can happen with many smart chargers as the battery will bubble & gas when close to full charge, & can do so in float mode. Shouldn't be a problem with a correctly sized ctek though.
If the smart charger does what it says it does, then ideally it shouldn't push excess current into the battery. But, I haven't tried leaving a smart charger plugged in indefinitely to see how it goes.
Quote:
Personally if getting a new battery I'd suggest you get an AGM battery which don't suffer the same problem because of their recombination technology. Additionally AGM's have a far lower 'self discharge' rate than wet batteries & if fully charged when you park up can happily be left for a month or more at a time without needing to be on a charger. I had no problems with YellowTop Optima batteries, although there are cheaper AGM's suitable for starting duties.
