So you made one then? Where's the pix?
Neither of the links you have posted have any Output info mate. I would not go near them.
If your happy to crack a casing then buy something with some specs and make it fit. It's only plastic mate.
I'd get something like this
http://www.ebay.com.au/itm/30cm-USB-...IAAOxyhS9TgAs-
And mount a dual USB under the dash and cut a small hole in the pod face to fit the female end of the cord and glue from the back so its flush and throw in a led in the pod and it will be back lit also :driving2:
I might even do in later I just need to think of a reason for more usb plugs.
Damn you 3d giving me more ideas
@ Mega texture the reason was I didnt want USB cables going everywhere running things like the DVR.
http://www.ebay.com.au/itm/351454052...%3AMEBIDX%3AIT
Ive brought this one and it will sit in the lower right hand corner of the windscreen,
then I can run the USB ext cord under the dash mat keeping it all neat, well thats the plan
My standard GPS screen fitted when new went on the blink and as I had GPS on my head unit I had the dodgy GPS took out and had metal plate fitted that's got 4 usb ports and the light switches for my front and rear light bars, looks great and should never need any more than 4 usb ports!
Thanks Tony I ended up fitting this one it did have stats
Hi Darren came across this one which also has a volt meter in it [red led].
as well,,,, you're after a higher amp unit aren't you this one says 4.2a.is that combined as 2.1a + 2.1a
I'm fitting it to either the inside of the lower pillar pod or maybe the LH pillar moulding if there is
enough room behind it.Red led is in the window when powered up eg 12.35v
Still trying to find that other gear for you to, Ill find it over the weekend for sure
Heres a pic of the voltage display on my dual USB port
