ET has had a few things on his plate lately so hasn't been on much, if at all. You'll be better off maybe sending him a PM as these threads also get buried quickly
Well written mate and spot on.
As you said the pi you posted is a perfect setup. We can't always have perfect but if you get a 3-4m ES or rope and a sleeve it will be the best option.
But remember the shackles. Ensure you always use the correctly rates shackles for the job.
hi Shaun ask at your 4x4 shop they may stock them, as they are used more now with all the IFS 4x4 on the road,
I designed a snatchem strap with that extra recoil strap about 6 years ago I think. Anyway if your local 4x4 shop
don't stock them go to your Cable and sling shop, they will know what your talking about
A good cable sling shop may even make one up for you out of SWR
I don't get why th op wouldn't give the name of who makes them.
BUT after a lot of searching...... I found them :)
http://www.comsew.com.au/?page_id=59
Its a common item now most 4x4 shops should stock them
I will have a look. The only 4x4 shops close to me are arb endorsed shops. So doubt they will have them
I would imagine they would.
good luck
Yeah at a price to match too.
http://www.supercheapauto.com.au/onl...d=218850#Cross
I have one of these
