They only sell road safe copies with a wire tack welded to a nut.
TBH Im not sure they even know what fits what.
Same as Clunks but a tad cheaper
http://www.ebay.com.au/itm/Racebred-...3D291465439070
this is what I'm talking about (the U shaped one) and I know it works because I use one
http://www.ebay.com.au/itm/Nissan-Pa...item43dcb1a75e
Still trying to figure out how I get the large U shaped plate into the passenger side chassis rail as even if I open up the front when it has been bent in, firstly there still isnt enough room to get the plate in, secondly if I were to use that plate or a nut welded to a peice of wire, I would have to put it into the chassis from the front, which would be difficult as I wouldnt be able to put my bull bar back on then....?????
Try and find Mudski's thread on fitting his two front S1 points
I think Mark made a plate to slide inside the chassis ,
the bullbar was off from what I remember of the pictures
here you go found the thread
http://www.nissanpatrol.com.au/forum...ecovery+points
