Have a look at this if you have time or unless you already have. https://www.youtube.com/watch?v=eSkM5sG04i8
HI, am pretty sure that the damper valve is the right way around, ports A, B and C on the solenoid are open to atmosphere, the needle valve is connected to the top port on the resonator as in Chez notes. Wouldn't think that the three ports being open would cause this as the solenoid is now out of the picture, as the valve inside the solenoid can slide all it wants it will achieve nothing, or is this my stuff up ??
thanks
Burto
no block it off like three dogs said its still connected to the computer
Will try that tomorrow and let you all know if that was successful, a very big thank you to you both for taking the time to assist.
Burto
No probs good luck mate
Hi all, well all is good now, blocked the ports on the boost control solenoid, as thought no effect, still 5psi boost max and high EGT, checked damper air passes through both ways so all good there, checked for vacuum at VNT actuator with engine at idle all good, took advice from video link, adjusted dawes 6 turns and locked, still have same problem, readjusted needle valve whilst observing actuator, no change.
Removed needle and dawes valve, and plumbed to original, 13psi boost in 2nd @2000, 15 psi boost in 4th @3000rpm, EGT 250, that will do me back to where it was 1 and 1/2 days ago
Will return for refund, thanks to all for your assistance.
Burto
where did you put the bung to get your boost
Hi, where its always been in the outlet pipe from the IC to the throttle body, as I already had fitted the boost and EGT gauges, sometime ago
BUrto
