Have you got a standard tank?
do you need also to put plate in for transfer case ?
Not for a 2 inch lift.
Tony
have put in two lift kit and now bit of drive shaft vibrating round 80km hr , should be ok ?
Have you swapped the shaft around so the thin end is up front and clearing the cross member?? Might be the thick end if the shaft touching the cross member that's giving the vibration? 2" lift shouldn't be an issue normally (I have 4" and have no vibration). Others will have further comment no doubt mate.
