You can do it in a lathe, use a torch and do it by eye or the best method is to make a bar that goes all the through the housing inc the centre and uses bushes/discs that slide onto said bar and into the axle seal area. Now if its straight they go straight into the seal are if not its clearly visible which way it needs to go.
