http://www.nissanpatrol.com.au/forum...id=54636&stc=1
I have a quick question regarding the setup of the needle valve. I have set mine up without a connection to the Air Filter Resonator and it works well. What are the consequences if any of not having a connection there?
Chaz notes the reason for the connection as: "
A clean air supply is needed to reduce the vacuum signal and its taken from the Air Filter Resonator, which is the same source as the ECU Solenoid Valve uses from "Port C"."
If the vacuum signal is not reduced does it cause more wear on the dawes and needle valves? I was told by the turbo place where I purchased the dawes to just bypass the whole lot and like I said it works fine.
