What maintenance has been done to the cooling system lately.
Could be due for a flush and over haul.
Had the same issue as OP and did the same as all other posters and removed the insert at the bottom of the shroud, which was fine until I decided to put the AC back in. On any day above 36 it ran to hot.
I went to see a Auto AC installer about the problem and he instantly pointed out the fan and shroud was the issue and went and proved it there and then. He placed a anemometer in front of the radiator it read 2.5Km/h placed it above the gap in the shroud it read 8.5Km/h (the Troll was at normal running temp AC off) turned AC on front went to 2.7Km/h, above gap 8.7Km/h (this is due to the electric fan turning on with the AC). He then cut a stiff piece of cardboard and fixed it to the gap between the shroud and the fan as it would of been without the body lift, front of Rad 5.9Km/h and 6.1Km/h with AC on.
This is how I ended fixing it
Attachment 56208
Attachment 56207
now temps are back to normal and recover faster after giving the Troll a flogging.
