welcome to the forum,
Hi and welcome
assuming it doesn't have climate control the air control flaps are controlled by cable check for the retaining clip that holds the outer of the cable in place i had the heater flap cable on mine come out of the clip which meant i always had hot air might be a similar issue
If the compressor is cooling and the blower is working then it could be pests nesting in the assembly. I had that happen to my nissan pulsar. Welcome to the forum by the way.
G'day Gene welcome to the forum mate.
Thanks to all of you for the welcome & advice. I can get the air to blow on my feet, & out of the defroster but none will blow out of the front vents. when in defrost it also blows out of the front window defogger. Thanks,
Gene.
To onlyme376 It does have Climate Control.
Gene
Hi this is Gene with the AC problem. When I put my ac on front vent it blows out of the foot well. I can put it on defroster and it will blow out of there & the side window defogger. Luckily the back ac works well so if it keep it on recycle it does cool of. it still will not put any air out of the front vents. Thanks Gene
Hi this is Gene. Somehow I got my Air Conditioner to blow out the front vents and it has been working perfectly. Then yesterday my granddaughter pushed the auto button on the climate control and it switched back to what it was doing before: not blowing out of the front vents.Thanks, Gene.
So when you turn "auto" off does it go back out the front?
When my granddaughter pushed auto it started blowing out of the feet vents and will not go back to blowing out of the front vents. Gene.
