It all depends on what you want to do with your truck Ben.
For years, all I had was 2 inch lift suspension - to protect the body sills, and give me a little more clearance, and I ran standard 31 inch tyres - because most of my running around was in flat desert country.
Now, I am always up in the Victorian High Country, I run 33's with my suspension lift. On my first solo trip up into the Vic High Country I ran myself into a fair bit of trouble - couldn't get the truck out, and had to abandon it and walk out till I found someone. This made me quickly realize that I needed to be self sufficient so I went and bought a winch ..... getting stuck always starts to sort out your priorities :hpfredgeorge1:
I think that your list is pretty good to start off, but I would do the following basic mods to get you going, and then reassess after doing a few trips - finding out what you like doing, and will continue to do, and then go from there
1 : 2" Lift Suspension
2 : Air Compressor
3 : Dual Battery System to cater for Fridge and Accessories
4 : Tyres
My list of mods is as long as my arm, as I now have heaps of gear in my truck, but I have built these mods up over a twenty year period - based on need, and not on magazines or what the bloke down the road has.
Things I don't have that I would like are Lockers, but for most of my trips they aren't needed. If I do get a locker, it will be front only - as I don't want to lose the benefits of the Nissan rear LSD......
Mic
