Im up in Bacchus marsh plan was to do a 3month trip with friends this year
Think id prefer diesel but some power would be nice
Hopefully you are correct.
Been a while i finally went with an L76 with the 6 spd auto engine out of a Ve ss.The engine should be in this weekend so hopefully have her back on the road within a couple of weeks figured the amount of trouble i had with trying to find a mechanic to fix the old 2.8 and the availability and the relative cheapness of the ls motors had nothing to lose based on on research and a guy i know who can tune the ls motors their claiming they can get 14 lt per 100ks out of it but we will see
Had the same problem just recently, common with Rd28Ts woodruff key lets go. engine still performing well like yours after a lot of research including replace engine the cheapest option was to strip down the engine have the crank titanium welded ,Why did i not just buy another second hand crank, ? because their like finding gold teeth in a chook, [though you might be luckier,] a new Nissan crank is worth an arm and 2 legs. you will probably need a new harmonic balancer of course, & if you decide to go this way replace your big end & main bearings as well. I also had it balanced, that has improved the power and fuel economy significantly, worth the extra $$ Replaced all the necessary oil seals & other bits & pieces too. Everything $ wise came in well under a second hand or new engine. Good luck mate Rob Ness
Hi it's a while back now i've got the same prob crank spun rolled wood ruff key broke edge off slot new balancer sloppy on crank at front but no movment at the back where it meets the crank timing gear. Gear also was on sooo tight it didn't move with the balancer. I have jb welded a new key and balancer back on to the crank yeah I know but hey it was solid although somewhat wobbly. Waterpump decided it was not happy about the current situation along with the cam seal.
Everythings back off just about to put seal in and reassemble I saw your post on here and was curious how your photos of the crank looked but can't seem to open the jpeg. I am logged in but the pointy finger doesn't replace the arrow to click on attached image.
Just went back to post and theres your image wow Iwas logged in b4 as now don't know anyway looks like mine Ithought for asecond Ihad posted photos of mine but I hadnt almost identical.
This is a pretty old thread and patrol 2.8 hasn't posted since 2017. I think you are taking a massive chance in using JB weld. If it lets go, the whole harmonic balancer might come off. I had a friend whose Pajero lost the balancer at 100kph. The balancer ricocheted around the engine bay and the damage was extensive.
