Hmm maybe I have it wrong, did read others saying the auto was really hard to get the same boost levels as the manuals at 100 kph(10-12psi), due to the differences in the rpm that each are at while cruising at 100 kph.
I can only get 14psi max boost without going into limp mode, so maybe that has something to do with it also, and not sure if you have a torque converter lockup mod and if that would change the psi readings as engine revving higher 100kph or if the DP chip helps with higher boost levels?
