Thanks all for your help. It's all appreciated.
With regards to the kit posted here, how is the metal probe fitted inside the radiator hose?
Andy, hope this helps: http://www.nissanpatrol.com.au/forum...ghlight=thermo
There is a threaded bung in the drivers side of the radiator on the back that you can put a temp switch in. I got one from a 3 series bmw that turns on at 92 deg and off at 87. I use this to turn the thermos on and off (at the same time) via two relays. You can also get twin stage versions that allow you to turn one thermo on at say 92 and then the next comes on at 97. If you want some more details I can dig them up.
I think the threaded bung on my radiator already has a sensor fitted. Is this for the ac fan?
As for the probe sensor, the instructions seem to suggest that the wire goes through the actual pipe and is sealed with silastic? Doesn't sound coshure to me.
Are you running the same style sensor Tod?
Yeah you could be right about that, I don't have ac! But if you are going to replace the engine fan with thermos maybe you can use it anyway?
Interesting idea. Does anyone know anything about the ac fan? What temp it turns on, does it only turn on when the ac is on? What size is the sensor thread?
IIRC the Thermostat for the factory fan is 95 Deg.
The "A/C fan" should run whenever the A/C is on or whenever the coolant temp in the Rad exceeds 95 ish degrees whether the A/C is on or not.
If you want to use it just tap into the wire and use a relay to switch the AU thermo's.
That will mean the existing fan will still work as normal.
From memory its M14 x 1.5 and it should have the temp range marked on it, I will check and see if i still have it in the morning.
Yes I've got the same, just went out and pulled mine apart as I couldn't remember.............
No silastic used, the probe has an olive ring around it which sits inside a brass connection, the brass connection is screwed into a plastic pipe using plumping tape, the plastic pipe between the 2 radiator hoses is just done up with clamps
Attachment 52417 Attachment 52416
Nothing I do is coshure *L*
