Rumcajs
Mine are set at low boost 12 psi high boost 18psi. Depending on conditions I found that keeping low boost on (I have over-ride switch where I can force either mode or automatic via TPS) on cruising will save as much as 1-1.5 L per 100 km. I also force low boost mode when engine is cold.
There is this strange thing about GU 4, where I have better economy in the city than on the open road and I have heard from the others the same thing. (GU4 owners)
It works with needle closed as well so I have very aggressive spool up and handy low to mid range torque doing it this way.
Regards
