Ok. It wouldn't hurt to get it checked with a dial indicator as the particular pump on yours can do weird things if the static timing is altered to much.
Not quite 100% mate. The later model td42ti did have some electrickery on and a very basic ecu. This uses inputs such as engine rpm, #1 injector lift, tps, coolant temp and one of the output controls the tcv (timing control valve) which is the plug right at the bottom of the pump that you were asking about.
Yes it's when they became inter cooled from factory that the electrics were added. They are very simple mate and aren't any less reliable then the older style. If something in the system does fail there is no limp mode or anything as such and the vehicle for the most part will be completely mobile.
To the blokes that had NATS issues. Im just trying to work out why it would fail and then thousands of ones out there are fine.
Did you guys do a lot of 4wding through mud or water?
Thanks Mate
I haven't had issues (touch wood) but I might get my mechanic friend to do it for me.
SO basically in a nutshell
Smash that black box open to get to the 1 wire protruding out. Then rejoin the middle loom wire to that one protruding wire?
I guess the scariest part would be hopefully not wrecking that 1 protruding wire in the process..
Also are we the lucky ones being td42t being able to atleast have this option? What do the 3.0 guys do?
Here is my experience from the first post seeking advice on why the light was staying on to smashing off with a wood chistel..
http://www.nissanpatrol.com.au/forum...OBILISER+LIGHT
lol yes I read that thread.
All I can say is you are brave and secondly thankyou for sharing as that gave us knowledge to save a lot of money or if we are stuck.
Im going to fraser island next year. I wasn't even aware of this NATS problem so im thinking I might get my mechanic mate to do before hand for me.
