No doubt about it eBay is handy for car bits. That autoelecac in Bairnsdale is a great example.
How did you go with this Macca?
Well it's been an interesting couple of days. Been pointed towards a exede HD not a Safari Tuff as they are too aggressive. Either engaged or disengaged no in between. Then found a gear box / diff specialist who owns a 4.2 GU . He is old school and fits OEM, he does not like the after market stuff saying it causes other components to fail. So he is fitting a new Nissan clutch, rear main seal etc on Monday. See how we go.
Was heading to the exede, other mechanics I know have all said stay with OEM as my Ute has done over 200000klm on the original so why change? I'm a bit conservative I suppose and use genuine Nissan parts where I can, filters, bushes, bearings etc. As to what other damage, I will ask him to elaborate.
i swapped from a standard clutch to the exedy and it did feel like a on off switch until I got used to it and after jumping back into my mates ute with a standard clutch the exedy craps all over the oem and my old girl has 450+km on the standard gearbox with no dramas at all
I put in the safari tuff clutch when the motor was swapped out 2 years ago and its never missed a beat. It did take a little getting used to compared to the oem clutch, but that only took a couple of days.
Extreme Outback
The new OEM clutch is fitted, the other one was nearly down to the rivet's so was a good time to replace it and the pedal was "hard" not that I thought it was unusual.
There were no broken springs but they were loose in the plate, that causes a lot of the low rev noise / chatter in the gear box, so I'm told.
It drives completely differently, smooth, quiet, softer pedal just nicer to use.
All in all I am very happy to have done this job before anything else got damaged.
The mechanic said the original clutch had copped a beating and "I had got my moneys worth". 206000 klm through god knows what before I got my hands on it then some good trips, long and short, as well as work it has had a workout. He was very impressed with its longevity.
So tonight I am one very happy Nissan Patrol owner.
