Overview of Setup 140W Solar Panel
http://www.nissanpatrol.com.au/forum...014/10/1.jpg?1
Battery & Redarc Solar Regulator SRP0120 20 Amp
http://www.nissanpatrol.com.au/forum...2014/10/11.jpg
Fridge 60Litre Fridge Freezer with Remote Monitor
http://www.nissanpatrol.com.au/forum...2014/10/12.jpg
The Battery is a 110AH Deep Cycle Calcium
The Redarc Regulator will charge two Batteries and you can set the Ratios ie Fridge Battery 80% and Caravan Battery 20%
and can be set for Calcium Batteries which require a higher Charge than normal Batteries
The Cables between the Panel and Regulator were obtained from Jaycar
I started the Fridge about half an Hour ago (Set to -19 degrees) and the Solar Panel is keeping the Battery fully charged whilst the Fridge Compressor is running continiously and has brought the Temperature down to -15 degrees
