I'm not 100% sure how they come off either, but you can buy replacement hinges so it's possible somehow. My guess is it's mounted internally and requires the door trims to come off to access the bolts.
You can unbolt it inside the door next to the speaker hole. I replaced the hinge from the original door and that seems to have lifted it a little higher. Thanks
2nd October 2014, 07:37 PM
Natolpatrol
Quote:
Originally Posted by angelo_f
Backed into a tree and the spare tyre buckled the door
This may be the reason why it dont fit anymore check and see if there is anything else bent.
4th October 2014, 08:16 AM
angelo_f
Quote:
The hinge off the replacement door was what was out. After changing it, the door aligns fine now
