Yes it is a good point. However if the fridge is cutting out when set at the 10.5v threshold, even with thin wire induced voltage drop, there is still every chance that the battery is is being discharged lower than is good for it if a long life is desired. But yes quite possible it won’t be as low as 10.5v at the battery. As far as the battery goes the voltage drop could be seen as giving it a little more protection. ;) If good heavy cable has been used the news is worse for the battery.
