Don't have a pic, I'll get one in the next few days.
I had my old GQ behave the same way. Timing was out. Minute adjustment of the injector pump timing and all was good again.
Hopefully you'll have it sorted soon
Hi guys, finally had a few seconds to take a pic, first how do i get to the idle screw? second whats that on top of my IP, why does it look different to Muddy's pic above?Attachment 49188Attachment 49187
If you have a small 1/4" socket set you can get onto the bolt that adjusts the idle. You should be able to get a spanner onto the lock nut. Its a little fiddly but doable.
That is a boost compensator. The idle just is still there and accessible just a little more tricky.
Done, idles much smother now, but as mentioned above very fiddly. Thanks to all that commented.
