All steering is good. Both sides are hitting. Panhard is adjustable and adjusted correctly. Nothing is bent or out of shape. All arms are new or near new solid chromoly and all adjustable. There is about 3-4 mill tolerance either side between the bolts and the radius arm.
I will upload photos soon, I currently have no digital camera of any form.
There are no sway bars attached at current happygu, which does not affect this issue. Yeah liftlid, superior engineered apparently, not so sure about that now.
I think that there has not been enough of a clearance margin manufactured into the arms to allow for bush deflection and the angular up-travel associated with drivers side flex, Factory arms are much slimmer. Also when you compress both front springs your diff shifts across. These arms are supposed to be designed with getting a lift engineered in mind, comes with engineers paperwork etc, but this obviously aint gunna to fly. I'm sure that someone else out there has to have had these issues before as these arms aren't a new thing. Only thing I can think of so far is to flex it up on the ramp and realign the diff off center sligthly so that when it angles up or across at full deflection it might not touch. Not real happy with that solution though as with such a tight gap a bit of bush deflection will still make it hit.
Cos, my partner works at United Fasteners and we are going through what i can use, but its not going to offer much more room to play.
