Sorry threedogs but it would have a transponder chip in it.
My suggestion would be to take it to a Locksmith and see what they can do.
Heres my spare key ,
looks like a normal car key to me.
Compared to the one it replaced
this one has more pronounced ridges,
and works just great on all doors and ignition
It does not come apart
Attachment 48247
TD, here is a picture of my VW polo key. The car has an immobiliser and will not work without the key. It does not come apart but there is a transponder in the key and the car wont work without the plastic part at the head. I think Snicko is right in saying that your key will have the same problem matey, bu there isnt any harm in trying a different cut key...
My 1998 GU Key has a Red insert (Near the Metal Key)in the Plastic Head of the Key which is the Transponder.
It is the same as my 2002 Nissan Maxima
See this :-
http://www.ebay.com/itm/Nissan-trans...59b6f8&vxp=mtr
Im going to try and open the other one , the only reason it failed was because it was worn down, not from any electronic failure.
my remote is separate, But Ill concede at this stage, till I open it
Yeah my key is worn down heaps, turns the ignition fine but really struggles to open the doors. Like you though I have keyless entry so do not worry about that part. I have a brand new spare key but it is not genuine and doesn't say Nissan so I don't like it... haha
It will have either a carbon wedge or glass chip in it. If you try to open the sealed key you run the risk of breaking the chip.
If the chip is broken then no one can read the information on the chip. Not a good thing. I would not recommend opening the key at this stage.
Take it to a Locksmith and he will let you know your options.
Had a good look at the key and it appears as you suggest that that there is a wedge next to the key[as per pic]
Ill take it to a locks smith, but what I cant understand is why a chip would require the key to be jiggled to work.
When the two keys are side by side its amazing the worn one worked at all
The chip has nothing to do with jiggling the key to make the vehicle start.
Your key must be so badly worn that it doesn't turn the barrel any more.
Use the good one and get another one cut and coded from a Locksmith.
