When fitting new shockers that have a larger bore diameter that stick you need to grind down the bump stop plates on the diff housing as they do hit the shocker. This maybe it. Check the upper mounts too. Make sure they are done up enough...
One other thing is to check if the back of the exhaust is hitting the cross member. Where it comes our of the rear muffler and goes up and over the diff.
