Says he with the birds nest under his dash!!!
Fixed it for ya too matee!!!
You wouldn't believe it. It has not done it once since last week.
You have an bull bar fitted?. and tow bar?.
My GU's "Factory fitted alloy b/bar" was wired with those dreaded scotch locks.
poor connections they are, if they don't completely cut the wires.
any way, had a similar problem right blinker having trouble earthing through the correct path to ground.
earth was finding it's way through parker light to ground, parker was flashing instead of flasher, wtf.
fixed by removing s/lock , soldered wires and self amalgamating tape to reseal.
hope that helps
No scotch locks in my car Robo. Everything is soldered.
I can't figure it out. It hasnt done it for nearly a week now.
Welcome to the world of electronics, mate.
Slightly off topic but I was reduced to tears trying to sort a wiring problem in my younger days.
It was (believe it or not) a wire that had continuity in one polarity but was open cct the other.
Because it was easier to get to the "wrong" end it would look OK on a test meter but DC wouldn't flow thru the bastard thing. Took me friggin' ages to figure it out.
It was a solid conductor that was broken inside the sheath so it was acting like a point contact diode
It was quite a few years ago now and I have lost the wire in my moves around OZ... won me a beer on more than a few occassions
