Thanks portal pat. Is there any way that I can test if that is the problem. Even when I press the priming pump a few times it still takes a bit to start, I would have thought that this would pressure the fuel system and (help) the pump in some way if that was the same problem as yours. If that is the problem it sucks, I have a few more things to check first and hopefully I find out it is something minor.
