and i checked all the fuses i could find, pop the caps of in engine bay and checked under dash and no blown fuses
The voltage reading at the back of the alternator should be the same as across the battery regardless of if the engine is running or not. It sounds like you have blown the main 100amp fuse near the battery.
Did you disconnect the battery when changing the alternator?
If the wires are large black wires, yes they need to be connected to earth. On the top alternator mounting bracket there is a threaded hole that I normally connect them to. Just find yourself a suitable bolt. You might also need to cut the tape from the harness to get some extra length in the black wire if they don't reach. These black wires won't stop the alternator from working.
great news!! so after checking over all wires, checking power in switches traced it all back to the nut that is inside the fuse box next to the 100amp fuse which connects to the other 100amp fuse and then goes back to the battery..the nut was LOOSE!! thats why i was getting power but very minimal due to bad connection
tightened all up cleaned all terminals and now getting full charge and every things back to normal..feel bit stupid about it all but i suppose its the little things..
i did get a new battery and alternator out of it but probably due for replacing anyway..
thanks heaps for the help appreciate it
