Get yourself a Dremel mate. Best tool on earth! As for power source, its wired the same as you would for spotties. Its own switch where it can only be activated via high beams.
isnt it illegal to have the lights behind the drivers head and ontop of the bull bar
thought i read it somewhere not that long ago
I did basically the same as Mudski but put a 50amp Anderson plug on
so I could remove light bar or roof rack. Cables then went down inside "B" pillar to switch on dash
Wired to my Aux battery via a fuse/thermo coupling
Hey mate. I had to mount it down as low as possible and it sits just forward of my head. I had it up higher but I was blinded by the reflection off the white bonnet. All good now. I can also unplug mine when I want to remove the roof rack. I just used those Narva waterproof connections for this...
So if you mount your light bar on your roof rack, doesn't the light shine right on your bonnet and provide glare (i have a silver car so it could be some reflection)?
cheers
Mark
