Which fuse are you checking for the tail lights?
Have you checked/replaced the reverse light bulb?
All...
I have done as suggested, I now have super clean contact in the fuse box and new fuses (just to be sure). I have used a meter and the problem appears to the the switch in the indicator/light box on the dash, obtained another and will put in today. Hopefully that's the problem. Again many thanks to all for your advice
Nissan Cedric
All...
All fixed new switch (2nd hand from a wrecker). All lights working. Again thank you to all
Cedric,
Which switch did you end up replacing?
I had this very issue last night myself. It's usually the fuse, related to some dodgy wiring on a couple of trailers we use, but, no amount of fuse changing fixed it this time.
Thanks.
