Mud Gecko
I have a Di, according to the Nissan manual, MAF voltage should be 1.6v-2.0v. With a blocked EGR and no modifier, MAF voltage at idle is 2.2v-2.3v. Without my modifier and running 18psi of boost I will get limp mode at 2500rpm and just under 3000rpm @ WOT in 3rd and 4th. Limp mode is a combination of high boost and high MAF voltage. Usually if you go over 3.98v under 3000rpm you'll get limp.
With my modifier, I have tuned my MAFv at idle to 1.7v-1.8v. I no longer have that "fuely" smell at idle and I can tune out limp mode by raising or lowering the MAF voltage around those limp points.
If you don't believe me there is plenty of info on the "other" site, lots of guys doing it now.
