Alitis007
Lol this is exactly the same fault i had with my trol, couldn't hear the clutch fan engage. I removed the radiator cleaned it inside and out with the hose, I also put 2 thermostats thru it and a new viscous hub but the auxiliary fan would continually stay on plus if i was going up hill the temps rise, i had to drive with my heater on flat out to keep the engine cool.
Long story short my radiator was 40% blocked internally the only way to clean it properly is to remove the tanks and get the tubes cleaned correctly.
Ally radiators are not serviceable so if it gets blocked internally you can try get it cut open and re welded but you'll most likely clog it up again with slag. Get your radiator cleaned out and price up a 3 core copper/brass unit.
