What would be that one on a GQ or Y60? thanks mate.
You can use dot 3 or dot 4 brakefluid, you can go a higher number brake fluid than the OEM spec's but not lower.
You can also get air locks in the load proportioning valve, if you end up with a spongey pedal, try bleeding the valve and then the rear brakes.
