If the pump noise goes from loud knocking to a softer tap tap it is just priming. A few things for you to check below.
Is it your low fuel light that is blinking ?
Could it be the fuel from aux tank making float bounce ?
What port on main tank is pump outlet hose attached to?
Is the fuel sender on aux tank wired up?
