Having consulted my ‘advisor’ further I am informed that your set up for winching should work fine Ova50. :) My concerns were unfounded. If however you did want a bit extra ‘oomph’ for extended winching scenarios, you could run a heavy cable between crank battery positive and the winch via an inline high amperage manual switch. A warning light could be incorporated to remind you to switch off after use.
Cuppa
