thanks mate that's what I thought but my concern is can this damage anything ie. new turbo or is it just restricting its performance
it may be a wile before I can afford the next stage of the up grade there telling me im looking at around $5000 to have new monster pump and custom intercooler installed does this sound on the money or to much ?
In time it can damage your turbo as it has to work harder to keep supplying your engine with air in a leaking system. It wouldn't hurt to also check for exhaust leaks, check turbo mounting nuts and manifold nuts.
5k sounds normal for someone else to be doing the work. Do you know the specs of this "monster"pump and intercooler as this will give an indication of whether the costing is correct.
no I don't mate is being done by amms which has been highly recommended by a heap of guys being from bris im sure you have herd of them hopefully only good reports
they have been all over it and guarantee me there are no leaks anywhere
whys that whats the problem
I would be very carefull about running without an air filter in even around the block. any dust etc in the intake anywhere can damage your turbo very easily. I have had a nasty experience with this...
