rottodiver
Really don't need spring compressors for a 2 inch lift, and they area pain to use if you ask me.... When you undo the shocks on the rear and drop linkages ( I am not a mechanic so I don't know correct terms but you will see them the second you do the and know what I mean) you can lower the diff and the springs will fall out( providing car is high enough on stands) and the front is a little easier but same theory, but they will just fall in and out and just make sure the springs mounts correctly...
Sorry a little vague on terminology but if I can do the suspension anyone can..
Oh if you are using castor correctors you will need to get them pressed in
Scotty
