04OFF
You still retain the factory headlight set up, all you are doing is activating the headlight relay automatically from a different location, so now Headlights come on when IGN is on "regardless" of headlight switch position.
"But", if you turn the Headlight switch ON with the IGN OFF, the headlights will still come on just as normal.
But then if you are sitting in the car waiting for someone, and decide you want to listen to the radio, your headlights will be on ! (not a good idea)
