BTW sorry for the crappy pics its very dark at 8pm in tassie, will take some more tomorrow in the daylight
Looks great mate, I like the look of that!
Looks great. Have to keep an eye out to see if I ever come across any of that alucobond stuff.
Yeh I looked up the distributor in Perth but the number is disconnected!
From memory a few styles one has aluminium both sides with 3 to 1 expanda foam style stuff in the middle,
The other has honeycomb in the centre, structurally its tuff as, used for partition boards ,doors etc in aircraft.
Even the buffet trollies are made from it. lucky enough to find a large sheet years ago next to my car at the Airport. lol
Ended up making a 600x300x300 tuckerbox, trimmed in alloy angle, great stuff easy to work with
more pics by the day light. Just need to pain the edges and get black caps for the bolts and screws
Nice work mate. Looks great!
Sent from my iPad using Motorculture mobile app
tested it on the weekend, worked a charm, cant wait till we do a bigger trip to use it some more. With the left over aluminium i am going to build a wind brake, need to put a hook on the door for rubbish bags and so forth.
i use the AluCoBond at work and of course inside my patrol :)
I made all the interior panels with it, in a fashion metallic pearl black colour :) it's super light and won't flex, but it's not cheaper. I did use it only cause we can't use all the small pieces we cut from the sheets in building architecture. It's more or less 4.5mm thick, but if needed it's also possible to get the thinner DiBond, same materials but just 2mm.
it had got a nice insulation, panels are never too hot or too cold. Maybe with a thin layer of dynamat they'll be also acoustically perfect?
how much weight do you think your shelf could support? ish? really good idea
