Cheers guys !
Cheers guys !
I've got an ARB air locker in mine - had it for 6 years. Can't comment on the others. Not great for going around corners, but it will if you need to. I only use mine in bumpy terrain where the lumps are likely to exceed wheel travel. Without it, once one wheel finds fresh air, the power on that axle shifts to the wheel of least resistance - the one in the air, so a temporary loss of drive on that axle. With the locker in, any fresh air still results in traction on that axle, even if there's one wheel in the air. For the question about lockers on sand, unless it is a bumpy exit, you probably don't need it. Just drop your pressures as required. That's my experience, anyway.
Auto LoKKa brand for me !!! X a hazillion
