It will be tuff
It will be tuff
Adapter kit rocked up yesterday, gotta get a sump, extractors and my gearbox freshened up and then it's go time!
Don't use a truck sump unless you buy it from Marks already Modified. It will still hit the tierod. I did, so now I'm just extending the bump stops so it doesn't hit.
Troy
I'm going to use a truck sump and mod it myself and only pay half of what marks are asking for the same thing haha. $800 is robbery!
When you've done yours, do ya want to do mine??? HAHAHAHA
Wouldn't be hard, ill be doing the cutting and just getting someone else to TIG it up. The front of the hump gets cut down and a plate welded at roughly 45 degrees. Also relocate the drain/sump plug. Have a look at the design on the Marks4WD site. ;)
you also have to mod the pick up
The sump comes with all the bits, pickup shouldn't be hard to mod, when I do it ill document it all so others can go down the same path :) if I can't heat it and bend it to the position I need I'll get it cut and shut by the local hose and fitting mob here. I can't see there being $450 worth of modifying there so I'll still be better off and I'm sure people will appreciate a write up on how to do it. :)
http://www.marks4wd.com/media/catalo...m/img_9437.jpg
there ya go ;) that won't be hard to make
Looks good mate :) Have to follow this build ;)
